Pac Man Plus Issues
FrizzleFried
NAMPA, Idaho
I have a Pac Plus that is experiencing some issues.
First thing I noticed is that from time to time the ghosts will go through walls as if they are off track a bit.... they will even go off screen from time to time... almost as if they were an inch or so "off track"...
Second, from time to time the machine restarts at the attract right before the maze appears.
For the ghosts, check the LS161s at 1E and 2E. Mine did the same thing. I went to replace one and I pulled up a pin mount while desoldering, so I cant check to see if it worked, because I FUBARed it. But apparently, those two control the motion of the sprites.
