Pac-Man / Ms. Pac-Man PCB Repairs - Just Shaking My Head
Scott C
Donor 3 years: 2022-2024
Missouri
I picked-up a pile of Pac-Man and Ms. Pac-Man boards recently from an Operator, who's tech described them as in "various states of not working." That is good and I am going to use that "various states of not working..." in the future. :)
Anyway, he was not kidding... I got them on the bench and found every board had issues, but a bunch of them were just silly...
- Mix-matched PROMs (Pac-Man, Ms. Pac-Man, and Ms. Pac Attack)
- TMM2016P RAM inserted in 5E and 5F (these were labeled as 5E and 5F)
- 2732 PROMs in 6E, 6F, 6H, and 6J
- Broken PROM legs (original and replacements!)
Within these boards are two different implementations of the Ms. Pac-Man hack to remove the Ms. Pac-Man aux (one of these boards is repaired, except for missing all of the moving sprites... still working on that...). This particular board has two 2532 EPROMs piggybacked at 6H and 6J, with a jumper wire to each from 7N, with another wire on the back connecting 7N to the Z80). It's a cleaner version of this hack compared to others I've seen.
Within some of the other boards, I found a very poorly re-installed 285 socket (it's so loose the 285 won't stay in if tapped or the Pac-Man board is turned at an angle) and numerous burned edge connectors. Also, ran across a board that had no sound after everything else was fixed. Turns out someone replaced the amp chip, but must have stopped half way through since some pins were soldered together where others weren't solder at all (fixing all of this restored sound).
I won't need all of these when done, so I will be putting them up for sale. Just wanted to share, so thanks for letting me ramble. :)
Scott C.
Thanks for sharing! I love a good repair log read.
just curious: How much will the boards be once they are. fixed?
I ran across another board last night loaded with TMM2016P RAM. Was there some type of hack or kit that used these rather than the traditional 2532 PROMs? This particular board shows other signs of repair, but none of the signs I have previously seen that are associated with hacks? Weird.
Scott C.
You're welcome.
Whatever the going value of Midway Pac-Man and Ms. Pac-Man boards. I repaired another two last night, but still have lots to go. :)
Scott C.
I just had a very similar situation. I bought a box of pac man boards off ebay that were all listed as not working. Turns out they had all sorts of mismatched pac/ms. pac chips and some were even backwards. Three of the six worked perfectly after chips and daughter cards were corrected.
Good luck!
Scott C.
Good luck!
Good to hear you got them working again. I have one sold already and have two more I'll be posting for sale ASAP. [emoji2]
Scott C.
Can I send you mine to fix?
I have an extra I'd like to have in case mine goes down in the cab I have now...
