Muffindude Active member VAPS Joined Jul 8, 2010 Messages 345 Reaction score 114 Location Richmond, BC Oct 1, 2011 #1 Does anyone have a picture of the wooden frame that the 2 monitor brackets are screwed into? I am going to have to make my own, so measurements would help. Thanks in advance.
Kawydud Member Joined Mar 13, 2010 Messages 970 Reaction score 10 Location Strykersville, New York Oct 1, 2011 #2 Here is a picture of the Galaxian cab that I have, monitor brackets are identical. Will try to get you some measurements in a little bit. Attachments DSCF0754-1.jpg 97.7 KB · Views: 42
OP OP Muffindude Active member VAPS Joined Jul 8, 2010 Messages 345 Reaction score 114 Location Richmond, BC Oct 1, 2011 #3 Kawydud said: Here is a picture of the Galaxian cab that I have, monitor brackets are identical. Will try to get you some measurements in a little bit. Click to expand... Thanks, I would appreciate that.
Kawydud Member Joined Mar 13, 2010 Messages 970 Reaction score 10 Location Strykersville, New York Oct 2, 2011 #4 Ok, please keep in mind that these measurements do not take into consideration how deep the pieces fit into the cabinet since I cannot measure it. The two long pieces are 3/4" plywood, the old stuff that is exactly 3/4" They are 1-5/8" wide and 20 3/4" long. The end piece towards the back of the machine that fits under the long piece is 2-7/8" long, same width as piece above, and same material.
OP OP Muffindude Active member VAPS Joined Jul 8, 2010 Messages 345 Reaction score 114 Location Richmond, BC Oct 2, 2011 #5 Thanks for the measurements! Hopefully I can replicate these.
