Pac-Man/G07 ground strap, 60-1 ATX issues, power switch loose wire...
OK, here's what i'm dealing with now. Since I got this machine, the monitor ground strap has just been hanging from the monitor frame, with the other end looking like it broke off. Did some searching and saw it goes somewhere on the neckboard....well, I can't find where it goes or even a pic. Next, I'm putting a 60-1 board in with an ATX PS. Lots of searching with this as well but it was hard to find a definitive and dumbed down answer for a noob such as myself. Since the ATX supply will be powering the board, do I have to remove a transformer or fuses so I'm not giving it more power and overloading it? Also, i'll be using the P1/P2 fire button jumpers so I don't hack up the CP. I read somewhere that you have to tap into a ground for the controls to work. Anyone have a pic of this or can explain better? Last, I just noticed this wire hanging from the power button on top. Where does that go? Thanks for the help....i'm sure these have been answered a ton of times but I really couldn't find the definitive answers. Appreciate it!
