What is the yellow spacer on the pac-man daughter card called? I need to replace at least this one given it is missing a pin. Any idea who might still sell this part?
you can probably just use a 28 pin socket to achieve the same goal. they're needed cause the sub boards will crash into the chips on the main board. lol
Order today, ships today. SSW-114-01-F-S – 14 Position Receptacle Connector 0.100" (2.54mm) Through Hole Gold from Samtec Inc.. Pricing and Availability on millions of electronic components from Digi-Key Electronics.
www.digikey.com
It replaces the original socket. The second picture is a installation spacer made from the original riser card. It is important to insert this into the two new risers so that they stay properly spaced and perpendicular to the board before soldering.
