pac man cabinet
Tuck
Donor 2012-2013
Kamloops, B.C.
I bought a street fighter 2 but i think its in an original pac man cabinet there is some numbers stamped on the wood frame on the back they are 7826 3 it also had a plastic sleeve on the back door with the original owners kit in it. That is what led me to believe it was a pac man. I kow someone out there will know there serial numbers and is this a pac man
A serial number isn't going to do much good, as it's just a sequential number. Post a picture of the cabinet. I assume the original owners kit you refer to is a pac-man manual? A quick google image search will give you plenty of images of what a pac cab looks like.
Pics? A serial number won't help. What do you mean "owners kit" and what do you mean plastic sleeve on the door? Just post pictured.
My Ms. Pacmame has a number stamped on the edge of the board above the rear door. It came with the plastic sleeve on the door, but no "owner's kit".
By owners kit I would assume he means the manual. Plastic sleeve, the owners manuel was probly in a plactic bag or sleeve and attached to the back door.
