Pac-Gal PCB running 4-1?
SCUBA King
Donor 6 years: 2020-2025
South Lyon, Michigan
@jsouza i was wondering if it's possible to run your beautiful 4-1 on this jamma pcb?
I have gotten it up and running on Zola gal a bunch but this one is pretty slick but different layout.
Let me know if possible. Thanks!
Anything is possible. That said I suspect it may need a bit of a code rewrite. Pulling one of those 6116's and replacing it with a Dallas DS1220 or equivalent would most likely be the way to go. If you wanted to save high scores and get the options menu.
I assume there are no schematics available. Those would be helpful. It can probably be setup to run just the 4-1 without saving scores. One of the older versions of the 4-1 code. Can you send me a clearer picture of the pcb, so that I can read the writing on the IC's? Glare makes it tough to read some.
@madrits here are better pics. Sorry for delay. Had to dig up pcb again.
