Does this new version also include the intermission speed fix?
https://forums.arcade-museum.com/showthread.php?t=307411
Just finished installing the 3.4 upgrade and I'm loving the game selection startup. A really nice new feature, and the 30 second timeout for name entry is also a very nice upgrade to the HSS features!
What I've noticed is that if you tap both the P1&P2 start buttons, it goes back to the selected startup game, but if you click and hold (For about 2 seconds or longer) then release it will go the the game selection screen. I'm wondering if theres a way for that hold time to be adjustable in the options menu?
This would be useful so that if you want you could make it so if you tap P1&P2 it goes straight to the menu selection screen (no possibility of going to the startup game) or you could make the delay longer. (in second increments possibly or whatever is easier) Also, maybe an option to chose a single game mode that only lets the user play a game selected at startup? (That way you can still access the options menu if you want to change this)
I'm probably suggesting too much, but I see potential with this startup game design and how you've implemented it.
i have this running on a "Ms Pac Championship/Super Zola Pac Gal PCB". the board has a service switch pin (from memory, its on one of the undefined pins 26?). when grounded it makes the options item go away, but you can still scroll down to options and select it.
also have issues with the board not booting intermittently, but that appears to be related to the DS1225 as the original ram works every time. probably chinese knockoff DS1225's
I don't think 3.4 will run on this board ( I actually have another version that runs on those boards). If there is interest in a 3.4 update for those boards let me know.
@RtypeEman can you verify which pin this is for reset? I just picked up two of these and will be converting shortly. Would love to know how to turn off options on this one.i have this running on a "Ms Pac Championship/Super Zola Pac Gal PCB". the board has a service switch pin (from memory, its on one of the undefined pins 26?). when grounded it makes the options item go away, but you can still scroll down to options and select it.
I got his running and it was the easiest 4-1 conversion ever. Jus need to find which pin to ground so I can install a switch to turn off options menu.@RtypeEman can you verify which pin this is for reset? I just picked up two of these and will be converting shortly. Would love to know how to turn off options on this one.
Thanks!
Sounds like I misread the post from @RtypeEman. On this board (super Zola pac gal) there is no way to kill options access? @jsouza any chance this has been fixed? I know Dev stopped a while ago, but wasn't sure if someone had figured it out.I got his running and it was the easiest 4-1 conversion ever. Jus need to find which pin to ground so I can install a switch to turn off options menu.
Thx eman.i was never able to get the options menu lockout to work on that board
