P718-G remote board vertical hold issues
RetroInjection
Sayre, Pennsylvania
I am having vert. hold issues with my new Golden Tee 2003 remote board. There is no picture, but when I adjust the vertical hold, the picture appears momentarily, then disappears. The number on the board is P718-G. Where can I purchase a new board? Thanks.
Dave
It's easy to check the pots on the remote to see if any are broken, and replace them if they are. Otherwise check the remote cable and the connectors on each end. I had one that had a cracked connector on one end and it would make the picture go away when messing with the remote because the wiring would wiggle and the connector would make and lose it's connection on the other end.
A bad vertical hold pot would still give you a scrambled picture.
But if you really need a new remote board, you should be able to get one from Chad at www.arcadecup.com
When the pot is spun very fast, the picture flashes on the screen. The connections are secure. Could this be an issue with the video board?
