OUTRUN monitor colors?
Steverd
Spokane, Washington
Here is the screen on my Sega Outrun.
I put in a new capkit last week.
It's a WG 7600 or maybe 7601?
There's just no white and too much green.
I tried adjusting everything and just can't get it right.
I'm thinking about replacing the monitor.
Ideas?
Thanks,
Steve
Wiggle your video plug on the chassis to see if you have a crack solder joint. Put your black lead on video ground and red lead from your meter on each color( on video plug) and see if you get around 1 vdc or so and it goes up and down depending what is on the screen. If you have voltages there, then either you should check voltages on the neck board. get a manual. You could check for a green transistor( on neck board) short that is why you have so much green. Switch green drive transistor with blue and see if problem changes color then you know transistor is bad.If your voltages are good on your neck board i would look into rejuving the tube.
