Hi everyone
I purchased this cab without boardset and not able to test.
First inspection at home
Bottom plate rotten away
Rounded Corners on bottom gone by rot
Wouden Top plate above marquee broken
Original power supply board = gone
Psu that is installed=hantarex es300. Whissle when powered
Monitor hantarex e900e swollen caps (caps ordered )
Wiring loom seems adapted to fit hantarex power. Still all terminals are there
Speaker amp: seems missing.
Service buttons panel missing (made one)
And then this weird board. It seems for the sheaker motor. Small wires go to pin b18 en a18 and ground. That small board also feeds of the 230v line. I doubt that is correct.
I'm working on a pi shield that connects to the amp 50 connector and arduino to read analog
Inputs. Program works even outputs like start light, vibration motor out, etc. Rgbpi plus board on its way to feed rgbc.
