squall280
So after a very long time of searching I finally tracked down an Outrun 2 USA cabinet with Outrun 2SP boardset, not the GDROM version and upgrade Phoniex monitor. It was sold as working and I had it shipped over to me via Fastenal. Upon startup I am getting 2 reoccurring issues.
Issue 1 - This happens nearly everytime, I arrive at Caution 51 error code( Wrong video output settings of horizontal scanning frequency)
Issue 2 - A static green screen of pixelation where you can barely make out chihiro. This happens maybe 1 out of every ten times I power cycle.
The seller advised me he had the Caution 51 error occur and he power cycle it and it worked. I at this point must have down it over 100 times and I can't get it to resolve itself.
Researching it seems to show the dipswitch is the most likely culprit. I did a continuity test and it seems like the whole switch is dead. the positions are (1,2 off / 3,4 on / 5 off / 6,7,8 on)
Has anyone worked on these? The most likely solution would be to replace the dip switch, but I would like to see if there is a work around just to try and get it to bootup. I already have alot tied into this and don't want to lose my mind over it anymore.
