Opinion about MVS cabinet damage repair
Tighe
Richmondville, New York
The MVS I bought has some damage where someone tried to pry it open.
I thought I would tape along the sides and fill in the damage with epoxy resin.
Toughts?
Here is the damage:
vAwj
vAzv
just use bondo its easy to sand and cheap
i have repaired several mvs cabs with chuncks missing one was missing the entire side of the cp
epoxy will be to hard to sand and finish
Most people use Bondo. I don't think epoxy resin will be very easy to work with as far as molding, feathering, sanding and painting.
Thanks guys I will pick some up. Yes epoxy would be hard, I was just worried that bondo would be too weak for the t moulding.
Another question, I will need to paint the damage, which will be easy on the black area, but the red will be hard to match. It's not like I can take the cabinet to Wal-Mart to color match. Anyone know the mix ratio? The rest of the cabinet is really good shape I just want to repair the damaged area.
gildden
base gl6213- satin
clrnt-----ax-----kx-----r-----v
oz-------3-------0-----8-----3
384th --144-----96---236---292
i would use eggshell as satin is a little shiny for touch up
my neo
matched paint
gildden
base gl6213- satin
my neo
matched paint
Nice match, thanks so much!!! On your neo is that repainted too? Did you silkscreen on the white? I was was going to post a separate thread about Ms Pac. I want to build a new Ms Pac multi using my Galaga cabinet as a template since they are the same shape.
I know that people sell sideart, but the original was painted on. I wanted to know if anyone has gone the paint route. How is it done?
no the neo is all original (well excpt the 19 inch i stuck in it to replace the broken 25 inch)
as for the mvs side art ther eis a guy on neo-geo.com that sells the art in a stencel or as adhesive backed art
That is cool, just glad my cabinet is in good shape. Does anyone sell Ms Pac stencils?
