SilverDuck
This may or may not help, but when mine did that, I removed the main JAMMA harness from the PCB and took a pencil eraser to the connector surface on the board edge. It fixed it. Good luck.
If you can use a soldering iron then replacing caps is easy! And a lot cheaper than a new board!If it ends up being bad caps, I may just try to purchase a full working board. I'm handy with soldering but never desoldered and soldered new caps before.
Replace all of the caps! They can dry out after 20 years.I would attempt it if I found a working replacement board. Who would sell these caps and how do I know which one / ones need to be replaced?
I dont think I'm meant to own this game
Replaced the power supply, made sure all the wires were in the proper place, turned on the cabinet, smelled something burning and shut it off right away. Never seen any smoke or where it was coming from and still doesn't work.
This sucks!
I would attempt it if I found a working replacement board. Who would sell thesencaps and how do I know which one / ones need to be replaced?
