optic board for Operation Wolf
Jumbo_000 sent me a Complete Used Gun for my Operation Wolf game.
Item was as described
Packaged well.
There was no damaged whatsoever when received.
I only replaced optic board, with great care.
My gun vibrates, the gun sounds, the mortar launches/sounds, and the screen flashes white when the trigger is pulled.....
Still the shots do not register on screen.
I turned up the brightness on the monitor and cleaned it. I cleaned the gun lens and the plexiglass!
I plan on checking continuity from the optic board to their terminating points to board and terminal blocks on Saturday night with the help of a friend. We also plan to check for cold solder joints on the optic board.
Can any of you tell me what specific voltages I should see on the four pins that connect to the optic board inside the gun?
Red wire voltage?
White wire voltage?
Blue wire voltage?
unshielded wire voltage?
Please Help Me!!! AAAAAARRRRRGGGG!
Rob
