robgill2008
Hello guys,
I received a complete used Operation Wolf gun from Jumbo_000
He told me that he pulled it from a working game so I was only after the optic board inside the gun. The gun was packaged well and looked fine.
I replaced the board last night. It didn't fix my game. I want to assume the optic board he sent me was good. I wanted to ask some of you for help.
My gun vibrates, the gun sounds, the mortar launches/sounds, and the screen flashes white when the trigger is pulled.....
Still the shots do not register on screen.
I turned up the brightness on the monitor and cleaned it. I cleaned the gun lens and the plexiglass!
I plan on checking continuity from the optic board to their terminating points to the board and terminal blocks inside the cabinet this coming Saturday night with the help of a friend. We also plan to check for cold solder joints on the optic board.
Can any of you tell me what specific voltages I should measure on the four pins that connect to the optic board inside the gun?
Red wire voltage?
White wire voltage?
Blue wire voltage?
unshielded wire voltage?
Please Help Me!!! AAAAAARRRRRGGGG!
Thanks,
Rob
Red wire voltage?
White wire voltage?
Blue wire voltage?
Thanks,
Rob
