You need to try and isolate where where your problem is. Trying turning it on with the coin door unplugged. Press the fire button, does it reset? Then try unplugging the control panel (coin door plugged in), coin it up...does it reset? If you turn it on with both plugged in, (dont touch anything) does it reset?
