I have a C&D with a jamma adapter.
New leaf sticks, new fire button.
Screen and sound work fine.
Also, tested this on a friend's jamma cab, and everything 100% worked.
However, in my cab, when I boot, it automatically goes into test mode.
In test mode, you can see that all stick directions and all buttons are engages (showing as "1")
I checked out the CP, and it all seems plugged in fine.
I traced all the grounds and I don't think I see anything plugged in where it shouldn't be?
I know it's not the jamma adapter because it worked fine in my buddy's cab.
Any ideas what would cause this?
Are there any grounds that should not be connected to the PSU's ground?
Any advice would be helpful.
Thanks!!
Thanks!!
