WeeBo
Hi there, first time poster, long time Lurker.
I finally ran into a problem with my arcade.
I came home and turned my girl on, alas only the marquee and the monitor turned on. Coin slot lights aren't lighting up and the game doesn't start up. I've done wire tracing and checked the fuses. The game was working without an issue before leaving for work. The power supply doesn't register any voltage on my multimeter. It is a Peter Chou power supply. If the issue is the power supply, can I replace it with an atx power supply and does wattage matter? If you have any other ideas or suggestions, I would greatly appreciate it.
