oni2382
OK......how the hell do you remove them, without beating the back of the cab all to hell? And what are some of your horror stories in dealing with them. Thanks for the help.
+1 on the dremel...
Cut a slot and use a flathead to remove it.
+1 on the dremel...
Use an "Easyout"
http://www.toolprice.com/c=Pq4W2o9CEP0SJFyZVV1FGQFsu/category/screwextractors.spiraleasyout/
God's gift to pesky screw removal.......
Removal tool for "prison" screws:
http://www.grainger.com/Grainger/TAMPERPRUF-SCREW-One-Way-Screw-Removal-Tool-1ZLA3
The tool you show is good for the ones with two divet holes, but not for the kind that are like a stripped flathead screw that you can tighten, but not loosen. (not that I see that kind on many games though)
Wrong. This is exactly the tool for one way screws. The "tits" of this tool fit inside the narrow section between the sloped portion of the one way head. This allows the tool to back the screw out.
If that were the case then wouldn't a regular flathead screwdriver work as well?
