Another Idea Im throwing around is making a kit that will let you run both MK3 and UMK3 from the same board, as well as maybe also have like Juggernaut upgrade option , and any other upgrade option for UMK3. It would be be easy to use with dipswitches or just normal 4 or 5 way switch. , and only one WOLF PCB needed, but the size of this may make this cost too much to produce. I'll throw around the idea, if anyone is interested in one at around at least 130.00 each then let me know and Ill look into making this.
