bluestreak
Weird issue. Everything is working except.. when I 1st power up the units, the master refuses to see the gas pedal. I can unplug the power after 2 seconds and replug and all works fine. According to the block diagram, the gas comes off of the I/O board, but so does a multitude of other controls which work fine. I've swapped I/O boards and no change, but have not swapped main CPU stack.
Has anyone seen this before? Outside of this I'm finally "100%"
FYI, the power supply has a replacement CHao in it and not the original PS if that could be it.
Thanks for all the input in the past to get me real close to 100%.
