FS Parts: Omega Race pcb
tester007
Calgary, Alberta, Canada
One very clean Omega Race pcb. This is only the mainboard, so you will need the soundcard. Most cases if you have a dead game the mainboard is toast, but the sound pcb is fine I have found. I will have pics on this right away, or will send pics if I get pm's on this to buy to buyer, before purchase is completed. There is one eprom socket I want to replace on it still which is why I have not taken a shot of it. Should get that done on the 28th. This board also has all new ram on it.. just swapped out all that was on it including the BBU ram (5101). Battery looks to have been removed at a very early time as there is zero damage to this board.
$200 + ship. Ship to US usually runs $30-$35 for a pcb, but will get a quote.
Works 100%. I want to put a new socket on one of the eproms because the original plastic part lifts off too easily. Will also throw in that this is a Canadian pcb so has FAR less tarnish on the large edge socket contacts..etc than the southern US ones I sometimes get due to the dry climate here.
Have another board for sale, same deal as above. No sound pcb, but mainboard tested and working. Has new:
- crystal
- Ram sockets
- Ram
- new chips in output
- P,R,S1 all socketed and new
- other logic socketed and new.
- elec caps replaced.
- couple transistors replaced..etc..etc.
Damage from the battery (base) neutralized with CLR and scrubbed/washed.
Its pretty funny.. the music plays when you complete a level, and the next level starts before the music has ended and it gets all garbled trying to make all the sounds. Pretty challenging.
