God I love it when things like this happen...
I picked up the Omega Race from a local (and fellow KLOVian). The game came in pieces but the seller assured me that the of the 2 PCB sets, one worked and the monitor (WG V2000) worked.
He'd verified both by swapping in to his working cabinet.
He said that the cabinet I was buying probably had a bad power supply... he wasn't sure... but that the game wouldn't work in the cab.
During my break I was able to pop out to the garage to take a look. I checked all fuses and they all seemed fine though one is pretty corroded and will need to be addressed. The monitor is not in the cab at this time... I figured what the hell and plugged it in to see what DID work.
I press the interlock and notice a couple things.
1. Front control panel marquee lamp fired up.
2. Blacklight lamp inside the cabinet did not fire up.
3. The red LED on the PCB set came on.
4. No noise at all.
I figured since the monitor was a couple feet away and it's only a single plug I might as well see if anything comes on screen.
I pulled the monitor over and plugged it in. Upon pressing the interlock switch (which has no "pull" option curious enough) I noted the monitor fired up... the spotkiller fired for a second then went away...all good signs.
I was greeted with this:
W00T! Evidently the power supply WORKS. The fact I am getting ZERO sound concerns me slightly...though i was told that they THOUGHT they put the good sound board in the cabinet...but if I didn't get sound to swap the sound board with the other one... so that may be the issue.
I was absolutely stoked to see the game come up on screen.
