Omega race help
jmduncan
Manchester, Pennsylvania
Picked up a working board set from a member, when I installed them it boots to the main screen and rapidly beeps. The light on the board below the cp flashes along with the monitor..... Suggestions anyone?
UPDATE** Jammed Tilt/Slam switch fixed my beeping and screen and monitor flash.
Now the machine will not pass the start screen and has a bunch of garbage flashing across the screen during test mode......
****Update 8-16-12****
Found a ground issue with the help of a member, reseated the daughter card and now I am up and running. Will post some pictures tonight when I get home.
Slam switch was jammed(thanks Nerbflong), now I cannot get the game to play. It is set on free play and coins up when I tried it out, but it will not move past the main screen to press one of the flashing buttons......
Have you checked the +5 yet?
@Nerbflong where do I check for the +5v. I was just discussuing this with a member, but I have not looked at the schematic to see where I need to look for voltage. I am also looking for the edge connector orientation (maybe a pic) just to ensure I have the edge connectors on properly.
Great pictures. Now I will be anxious all day waiting to see if I have the connectors on properly..... Then I just need to figure out where to check the voltages. I have been digging through threads, but there are soo many about OR.
