Older (-023 board) K4900 & cap kit questions
dmarcum99
West Chester, Ohio
I have a Spy Hunter UR with rolling issues. I received this in trade so I' haven't had this very long. I have the older K4900 board (-023 board) and when I ordered a cap kit from Syracuse Semiconductors, the caps have different values than the ones installed. I'm just trying to figure out if these are going to be OK, or if I have to find another supplier..??
For example, on my chassis, C506 has a 22uf 160v cap.
I received a 22uf 250v cap in the kit for C506.
on my chassis, C313 has a 47uf 200v cap
I received a 100uf 160v cap in the kit for C313.
Another question, on C301, I have 2 capacitors in installed. They look to be twisted together. (1) 100uf 160v & (1) 220uf 25v ....is this right?? This can't be right...right?
For C301, the cap kit has a 330uf 50V capacitor
c506 they just gave you a higher voltage cap, perfectly fine.
c313 these vary depending on the 4900 model, you can probaly get a 47uf 160v cap at radio shack
c301 they just combined two caps to get the 330uf, just replace with your 330uf 50v cap.
per your notes:
that is fine. Same or higher voltage rating is fine. It's the microfarad value that needs to be exact.
The normal K4900 used a 100uf 160v cap at that location, but the K4906 is slightly different and used a 47uf 160v cap there. It'll probably work with the 100uf, but if you can get a 47uf, use that.
As stated, they probably didn't have a 330uf and used two to do the same job. Remove them both and put in the 330uf...
