Old quad-voltage PC AT switching power supplies $5 each
What makes these so special? I saved them because they all have hard on/off switches which are not always found on the newfangled units out there today.
These have the AT power connectors (P8 and P9) as well as a few of the four pin connectors for hard drives.
There are five available, each is a little different so please see pictures and description below.
One
Has AC pass thru and leads for a remote power toggle switch.
Two
Has a black plunger type on off switch (seen to the right). No AC pass thru, and in fact the female AC connector was removed so a cord would need to be spiced the the leads which remain.
Three
Same features as number one: AC pass thru and leads for a remote power toggle switch.
Four
AC pass thru and a remote mounted push on/push off power switch.
Five
No AC pass thru, chassis mounted on/off rocker switch, and no P8/P9 connectors.
One
Two
Three
Four
Five
