Old arcade boards to Sony PVM.
Finch
Santa Cruz, California
I've got a Gorf board that might work, and a monitor that doesn't. I also have a Sony PVM broadcast monitor that accepts RGB+sync.
I've hooked a Neo Geo motherboard up to this monitor, so I know it works with arcade boards that used RGB and a single sync line, but Gorf seems to use separate H and V syncs that are (would need to double check this) hooked up to the neg sync points on the 19" G07 that came in the cab.
Can I somehow hook Gorf up to the PVM, without having to do any fancy stuff in order to combine sync signals/flip them etc?
yea, nothing happened.
Although by "nothing" I mean there was nothing on the screen, earlier when I accidentally just hooked the ground to sync I got the "no sync" signal.
The board I'm working with may or may not work, so I was just trying to use the PVM as a test monitor while I'm fixing the one that came in the cab. So could be that the game isn't running.
thanks.
