Ok, shot in the dark, can anybody identify this tube pinout
Gov
Springfield, Missouri
I know it is a long shot but does any body know if this pinout is compatible with any 13" chassis neckboards? I had this 13" Orion TV lying around and cracked it open for the hell of it. It has a Sharp tube in it and thought on the off chance it might be compatible with a chassis out there, it would be great for a DK cabaret scratch build.
If not that is cool, I can use it for target practice or something ;)
Uses B & K rejuvenator socket # CR-31 so this is a small neck tube (22.5mm diameter neck). I see in my notes this was used in some Wei-ya & Eygo 13" monitors.
So is this pinout the same connector? It is from a WG/Orion monitor tube that was pulled out of a non-working Pole Position cab. It is 19" however, anybody know what chassis mates up with it? It has matching WG serial numbers on the frame and tube. Again, the tube is an Orion.
A cr-31 yoke and chassis. Depends on the tube size. For 19", a 19" K7000 chassis and yoke would work..
Very good. Thank you for the info, I will see what I can find. Do you think the yoke that is on there is from a K7000?
that is no yoke i have seen before.
you will have to measure it to see what the pairs are.
ohm's is what you want to measure them with.
a K7000 can tolerate a wide variety of yokes without having to swap them.
Peace
Buffett
Alright. If they are under the heat shrink you can just put the leads into the open ends of it.
19" Daewoo DTQ2023FC A48JLL40X
Horiz-3.5ohm
Vert-14.2ohm
Manufactured August 1994. Drop-in Replacement for K7000, yoke works. Perfect fit.
Yup looks perfect to me. As long as the neckboard connector fits with the tube pins your good. Can you do me a favor and post the TV you got as well and the CRT number please for record keeping?
