phineas foo
Permanently Banned
I am going to list below the molds I have and master parts I can take molds of to make new items. I will post a price next to each and see what and if people are interested. If they are I will post a new sign up thread and then get going on the project people want most.. so on and so forth.
Outrun control panel - Formed plastic with the proper holes drilled out/cut out Nothing more. No paint. Just a cover you paint and remount. Done in white ABS so it can resist cracking and has more flex than the original styrene. ABS parts have to be baked out before you can use the plastic to form them so the price is higher as it needs to be .093 think - 75.00 +ship (10 people minimum needed to get this going)
Outrun mini control panel. This part looking at it is a total nightmare. It needs to be reinforced from the inside on the shifter area, where the originals break all the time. So this has to be made and then adhered on the inside. Also should be done in ABS as the original was done in plain styrene and then a crappy hammered paint added. This wont need paint at all. $75 + shp (10 people minimum needed to get this going)
Lunar lander new control thruster plate. The original was done in .187 plastic. Why? Who the hell knows. A .093 works just as well and has better detail. Mold is done and can be formed now. black abs and white available too if you so desire - $30.00 + ship
Monitor bubble for Midway games. .060 plastic better flexibility than the original and is brand new with a slight mod to make it harder to make it flex all the way to the neck of the tube. $40.00 + shipping
Battlzezone joysticks - 4 halves to make the joustick set complete done in a high impact resin. Pop out your original screws and nuts and add them to these. $40 per pair shipped (need 10 sets ordered to get this rolling)
Inferno/blaster joystick - one joystick halves only no hardware since i have no clue what they came with. Same black resin as the battlezone. Price is for one joystick - $25.00 shipped. (12 sticks needed to get this rolling)
So here is the list. Giving people a chance to see if we can get this done. If not no worries. I am not going to be hurt or anything. Dealers if you want a run contact me and I will cut you a good rate for a minimum run or if you want to get all these done and have them as an exclusive for your store.
