oh oh, now what is this on a GO7 chassis?
cmkryzer
Minnesota
Ok, I have recently posted on here that I was having problems with my Pac Man Jr playing blind with a GO7 monitor
Well I ordered a cap kit for it , Discharged the monitor yesterday, went out last night to pull the chassis off, got the first rear screw out, went to find the other screw in the back of the chassis, or the front of the cabinet, and I stuck my hand back there and felt another fuse...I thoought what the hell, pulled out the fuse, and walla, blown , dug up another 1 1/2 amp fuse, stuck it in, plugged in the rest of the plugs, fire up the machine, and blew that fuse out again.
So any Ideas what this fuse is for , its mounted on the back of the chassis, or towards the front of the cabinet.
I still plan on going thru with the cap kit, just wondering about this fuse?
there should be 2 fuses on a g07. one in the bottom left hand corner and the other next to the filter cap....sometimes people will remove them from those locations and run wires from the solder to a fuse holder placed outside the chassis for easy replacement.
Once you pull the chassis look to see where the fuse is in the circuit. My guess is someone paralleled one of the pre-existing fuses for ease of troubleshooting, since the G07 fuses are soldered into place.
