Bullwinkle
Working on an Offroad Thunder, the "thumb" nitro button on the shifter is not working. I've tested continuity with the machine off and it does not make proper contact when depressed... so it needs to be replaced. I can't seem to figure out a way to replace just the switch which is located in the handle. I don't see any info in the manual other than the shifter as one complete unit. Is there any way to just replace the switch for the button?
Thanks,
Tom
EDIT: apparently one of the wires connected to the switch has broken free, but again, how to disassemble the shifter to get to where the wire needs to be soldered back to the switch.
Thanks,
Tom
