Hi guys i have an offroad challenge , i have tried subbing in several monitors but get what looks like 3 horizontal pics , i know its a medium res and i have tried changing the sync any other ideas?
changing syncs doesn't have anything to do with the lines of resolution the game outputs. you're trying to run a standard res monitor on a medium res game, that's why you have triple vision.
the replacemnent monitor is supposed to be a med res , from a sega , i guess i should get the specs and make sure , the vendor i purchased it from is a well known vid guy in our area and knew i needed a med res.
i read up on it , its a duel res , i changed the connector and now have a pic , but now i have to figure out how to degaus it , its a sega monitor with the two red wires but obviously they lead to nowhere in my offroad.
they would ordinarily go to an AC pushbutton. I think you might even be able to just hotwire it momentarily, but wait up and see if someone else has a better idea. it's just powered by AC, the degauss coil, if you got a button or switch that can handle 120 VAC, then rig that up. press it once, should take care of it.
