OFFICIAL THREAD for Asahi Seiko Parts (Nintendo Coin Mech)
NERDtendo
Republic , Washington
I was notified by Asahi Seiko USA that they are no longer going to support coin mechanisms. They are going to refer all customers who need replacement parts to MikesArcade. This means that what I have in stock is all I am able to get. Once I am out then that's it. I will update my first post to reflect items that I have in stock. If an item is out of stock it will not show up in this post.
You are responsible for the part cost, shipping cost and PayPal fees. If you really want to send as gift payment then I won't stop you but I prefer to keep this as legit as possible. I will be using this site for the PayPal fees calculator... SaleCalc
If you want to place an order: PM me with the parts and quantities that you need along with your location. I will respond with your total and my PayPal email. If I do not have the quantities you seek or run out of a part I will let you know and allow you to revise your order or be placed on a "Notify when in stock" list.
SHIPPING COST:
Shipping will be entirely done in flat-rate USPS boxes. This is to make everything as simple and fluid as possible. Whatever will fit into the size box is the shipping cost for the entire order. Delivery Confirmation is included in all of the shipping prices (Delivery Confirmation is only available for shipments in the U.S.). Here are the prices directly from USPS:
Small Falt-Rate Box: $5.80 (domestic) / $19.95 (Canada & Mexico) / $23.95 (all other locations)
Medium Flat-Rate Box: $12.35 (domestic) / $40.95(Canada & Mexico) / $59.95 (all other locations)
Large Flate-Rate Box: $16.85 (domestic) / $53.95 (Canada & Mexico) / $77.95 (all other locations)
This is the official list of parts that I available.
Model 740 Parts:
740 E-Ring ($0.50 each)
740 MicroSwitch Mounting Set (2 screws for mounting microswitch to the coin mech) ($1.00 each)
740 Face Plate Mounting Set (4 screws and 4 washers for mounting the face plate to the coin mech) ($2.00 each)
740 Bugle/Return Cup Mounting Set (2 screws that attach the Bugle or Return Cup to the Faceplate) ($1.00 each)
Model 730-A Parts:
730-A Cancel Cam ($1.50 each) ONLY 2 LEFT
730-A Set Screw ($0.50 each)
730-A MicroSwitch Mounting Set (2 screws for mounting microswitch to the coin mech) ($1.00 each)
730-A Face Plate Mounting Set (2 screws and 2 washers for mounting the face plate to the coin mech) ($1.00 each)
Upgrades:
Return Cup Large ($5.50 each)
NOTICE ABOUT BUGLES: There are two different types of Bugle. Be sure to specify which model your want in your order if ordering them separately.
NOTICE ABOUT RETURN CUPS: The large return cups will only fit on the Model 740.
Here are the differences between the two model coin mechs...
First, the Model 740 uses a cancel button for coin reject and the Model 730-A uses a lever.
Second, the microswitch assembly on the Model 740 is located on the bottom with the connectors pointing down and the Model 730-A has the microswitch assembly mounted on the side with the connectors pointing out to the left.
Third, which is an extension of the second, is that since the connectors on the Model 740 are flat and facing down as soon as the new mechs were installed and the coin door was shut for the first time the lack of clearance from the coin box causes the first two connectors (which have wires connected to them) to bend. It doesn't affect the function, but it does expose a slight design flaw as this is not an issue with the Model 730-A.
The Model 730-A is a better quality, more sturdily built mechanism in that the lever coin return functions much better than the push button of the Model 740 and tends to require less maintenance. This is why the Model 730-A is more expensive.
The Model 740 was generally standard on the original Donkey Kong and the Model 730-A was generally standard on the Donkey Kong Junior cabs.
Both models are correct on any Nintendo machine in the sense that Nintendo used both mechs and it is not uncommon for operators back in the day to upgrade and change mechs based on quality, availability, and pricing.
6 x Lockout Security Mechanism for Model 740 Mechs (stops coins from being inserted into the coin mech when power to the machine is off…requires +12VDC…no harness included) ($5.00 each)
OP
NERDtendo
NERDtendo
Return Cups:
Micro Switch Assembly Parts:
The shorter Actuator wire that is mostly straight is for the Model 730-A and the longer Actuator wire with all the bends in it belongs to the Model 740. The MicroSwitch itself as well as the Retainer Cup is the same for both model mechanisms.
OP
NERDtendo
NERDtendo
Dan, can you help me out, I need one return cup for my DK Cabaret, how do I identify the model and size I would need?
They don't make the original, smaller cup anymore. The model listed above is the only one available for purchase today. The only way to get an original is to scour the internet until you find someone selling an original. However, if you are wanting a new one like the one shown above to hold you until you find one, let me know.
Tighe
Richmondville, New York
Oh OK, my right side one is cracked, but still usable. I think I will stick with it for now. :D
JonnyNeedles
Madison Heights, Michigan
I am missing a couple parts on one of my original 740 mechs in my DK.
I'm missing the spring on the microswitch, and the guide that shifts to the left to return the quarter when you press the pushbutton return.
In the images attached, I outlined the parts missing from my mech.
If the unrefurbished mechs you have contain these parts, or I can swap the entire mech while leaving the exterior original (cup, pushbutton, faceplate), I would be interested in one unrefurb mech.
If the unrefurb mech comes with the bugle, I would also like to order 1 extra bugle.
Thanks!
OP
NERDtendo
NERDtendo
Thanks!
My unrefurbished mechs are complete and fully functioning. They do not have bugles on them. They are as they came to me (you can see an example of one in the comparison picture above). You are able to transplant your original fronts of a Model 740 to another one (old or new). Just PM me with the items you want, the quantity, and your location. I'll repy with your total and my PayPal email.
OP
NERDtendo
NERDtendo
One of the unrefurbished coin mechs is gone. Quantity has been changed in the original post. When the items in the "Temporarily Available" section are gone...they're gone. They are just what I had in my closet and the old ones that have been replaced with new ones.
ALSO...
If you have a set of small return cups that you would be willing to sell/trade to me...I would be very interested!!!
OP
NERDtendo
NERDtendo
one question... how is this "OFFICIAL" you now a rep for them?
"OFFICIAL" as in my official for sale thread. I had another thread running for about a month and a half talking about my upcoming order and my transition to small projects to help the arcade community instead of my old cab flipping stuff I used to do. The other thread once I posted prices and pix got people confused. Too many people were having trouble finding the parts, then going to page 4 to see the pix, and then going back to get their prices and quantities together. I copied the updated first post and all the pix to this new thread and directed the followers of the first thread to the OFFICIALLY for sale thread.
It's also a play on my OFFICIAL PlayChoice-10 Price Guide. Trying to stand out in the sea of the world wide web. Also, they are Asahi Seiko brand new parts, the Original Equipmennt Manufacturer for Nintendo coin mechs. I am not a jack-of-all-trades, I have mostly worked with Nintendo so when I finally got to the point where I can't work on full games or soldering I decided to go with what I know.
OP
NERDtendo
NERDtendo
Dan, did you see my message? What size do I need?
The large ones here will work, but to be all original you will need the smaller size. You have the smaller size on your cabaret right now. You weren't kidding about them being cracked. Holy cow.
Tighe
OK, I guess it will have to wait. It is just the one that is cracked. :D
Malice95
Howell, New Jersey
I have two 740 mechs on my DK with cups. Both need a cosmetic facelift. One is missing the cup.
I like the look of the 740 mech with the bugles though. Big chrome fan:)
If I buy a 740 refurbish kit w/bungle for each.. will everything fit my 740s that have the cups?
Do you want the old cup? I think its small.. dont have anything to compare
it to though.
Just looked again.. mine are both missing the switches, bolts that hold the switches in place
and the wire that is tripped by the coin. Do you sell those parts?
Top
