Off the wall switcher question....
radioflyer
Clarendon, Pennsylvania
Been buolding a spray booth for my airbrush this week, and wanted to put in a few small coling fans, and since I have a bunch of spares here from a few games I gutted, figured I would use them.
I want to hook them up to a spare switcher I have here, but how should I go about doing it?
Are they 24vdc 12vdc 120vac fans
what kind of switcher? What voltages does it put out?
What are the current requirements of the fans,
will the switcher handle that (which it should)
You need to give us more information.
Simple answer connect the fan to the correct voltage output.
What output voltages does the switcher in question have? You need to know what yours puts out to know what voltage fans to use.
Remember that multi-voltage (+5, -5, +12, etc) switchers MUST have a load on the +5 volts for it to work properly. You can't just hook up a +12 volt fan to the +12 volt output without also having a load on the +5 volts too.
