Odd TZ opto problem
JASaxman
Beckley, West Virginia
On the upper right side by the first Magnet, the Opto is giving me problems. When you first turn on the machine everything works fine. No errors, and game play is great. After almost an hour, the Opto there will stop working, and will not work again until you cut the machine off, and then back on.
I've checked the opto with a display to make sure its still emmitting, and it is. I've also gently cleaned the lenses hoping it would help, and nothing, same effect. Checked wire traces, and everything checks out fine.
Any idea's?....it's really starting to drive me crazy!!!
