baritonomarc
My Paperboy is in the need of a brand new 25A 32V slow blow fuse, but here around is no more available because "obsolete". Now, is there a rule of thumb, like with capacitors in which you must keep the capacity value constant but you can use higher voltage caps? Can i use, for example, a 25A 250V fuse?
thanks
thanks
