Did anyone at the show play the Stargate? If so where can I get the bottoms on the control panel? Mine sit up way higher and as such is much harder to play, the buttons an that Stargate where great.
Thx,
Thx,
WMs Stargate Short Button Set $12.00
I think those are what you want. I'll be buying some in a few months.
http://therealbobroberts.net/parts.html
Thx,
Yes played it, they are not the correct buttons. It has micro switch buttons in it now. The ones you have in yours are prob original leaf switch buttons they much better IMO. I asked Matt about the buttons, seems the panel might have been hacked before he got it, and now it wont take the original buttons.
Most of the leaf-switch button replacements you see now are not like the originals. They sit too high and the springs are much stiffer than the originals (and no, it's not just from wear... the gauge of the spring metal is clearly heavier). I pull the springs from the old banged-up buttons and use them in the new buttons. Then I put washers underneath the c-clip so that the button sits in a comfortable resting position and the action is correct. Then you need to adjust the leaf-switch blades so that they are sensitive and self-cleaning (a full press should cause the contacts to wipe a bit). A properly adjusted leaf-switch button should kick ass....
