NSM Festival keeps blowing two fuses, no 5v +/- LED on central board
nagamitsu
Cambridge, ON, Canada
NSM Festival, should be same/similar as other NSM jukeboxes, ES160 central units were used in several NSM jukes. So here's the odd thing, had not fired up the jukebox in months. Fired it up today, played 3-4 songs successfully, walked away for a bit and came back to see no display for selection/credits. Opened it up, and noticed two LED on central board not lit for the 5v+ or 5v-. Noticed SI2 and SI3 fuses (2 amp, slo-blow) both burnt out. Picked up some fuses, swapped in and had a few seconds of LED lit for the 5v and they then turned off. I had everything disconnected from the central unit (only power in) when this happened. So it is something failed on the central unit board system, but not seeing anything burnt, no swollen capacitors etc.
Tim
