NSM City II carriage problem, need help!
ollihd
ESPOO, Finland
Hello,
This is my first post to the forum, hi all!
I'm trying to fix a NSM City II jukebox. The jukebox turns on, let's me select a record, but when the motor starts spinning to move the carrier, it spins in the wrong direction.
It's stuck in at the right side. If i manually push the carriage from the right side to the record, it selects the record, starts spinning (in the wrong direction again).
Any ideas where to start looking for the fault?
Thank you in advance!
Party like it's 1999.
I had a couple City II when I run the FT Gordon Account in 1999. There are two transistors on the carriage. On driver it right. The other left. When 1 quits the carriage moving that direction. Do you have a manual? I would replace both and make sure carriage motor is wired correctly. Other than that problem they worked great.
