Novice needs advice...Power Supplies and JAMMA
rainman154
Buffalo, Minnesota
Hey all,
I need some advice. I am trying to rebuild a Donkey Kong with a 60 in 1 iCade JAMMA board.
I have a 2001 Pentranic monitor and an original DK speaker. That's it.
So what type of Power Supply should I get??? There are so many and I want to make sure I get something that will be fine for the JAMMA board and with my monitor + speaker.
I don't believe I need an ISO since the monitor is newer. Do I?
Thanks in advance! I wanna get this thing built soon and post pics.
http://www.twistedquarter.com/index...roducts_id=4&zenid=g4lvphqjkgno654f5j8mscb9q3
this would be something that would work for you.
The newer monitors typically tell you if they do not need an isolation transformer. I always made it a habit of using one anyway, even when I used a vision pro or something that "didn't need one"
http://www.twistedquarter.com/index...ducts_id=364&zenid=g4lvphqjkgno654f5j8mscb9q3
For $17, it's pretty good peace of mind for your expensive monitor.
I buy all my stuff from www.therealbobroberts.net but I have used twistedquarter.com and they are very good (and take paypal) bob does not.
You might check out Arcadeshop as well. Many people sell JAMMA harnesses for $10-15. There's is more expensive at $55, but it has all crimped on connectors and molex connectors to connect to the power supply. $40 extra sounds like a lot, but to have everything crimped and labeled...you'll save yourself 5 hours easy if you don't know what you're doing.
Agreed, and you are right, I DON'T know what I am doing. I have an end idea of what I want, it's just knowing how to get there.
I also talked with Arcade Shop Amusements and the lady told me to get the Multicade Upright JAMMA wiring Harness for 19" monitor and control panel. It is $55. Plus I would have to get their Power SUpply and I think that was like $30 or so.
Anyone ever bought that one? I just want something that allows me to simply plug and play.
Just burn the cabinet and save the humiliation of ruining a perfectly good Nintendo Classic Cab.;)
actually the cab was going to get burned at a bonfire. I saved it to restore it. From the outside you won't be able to tell it is a 60 in 1. It will look just like a DK. Just wait until the finished product.
