SOLD - PARTS NOS Wico joystick with red and blue shafts
Arcadedl
Massachusetts
Clearing out a parts box and came across this, you will get the NOS joystick base and two 3.5 inch shaft assemblies (one red, one blue), washers and instruction sheet - everything shown in the pics. Full disclosure: the red ball has a ding and abrasion on one side as shown in the closeup pic
SOLD
Based on the instructions - the actuator determines whether the assembly will allow for 8 way (.600 diameter) or 4 way (.500). The actuators are .600 in both cases, meaning 8 way.
To clarify, the holes in both the top and bottom matter. For a proper 8-way (as this one is), they are both round. For a 4-way, they should both be diamond shaped.
Ops would often mix and match stick parts, so there are a lot of frankenstein sticks around, but the top and bottom holes should be the same shape, if you want the stick to function properly. Otherwise the stick will wear incorrectly if the top and bottom are mismatched.
Also, there are different actuators for 4 vs 8-way. 4-way is a thinner sleeve (i.e., more like a tube, of constant width), whereas the 8-way actuator is the thicker one shown here (to allow activating two switches at the same time).
