Noob with questions about WG U3100 monitor (and arcade monitors in general)
(cross-posted at BYOAC)
So I've had the itch to build a MAME cabinet for years, and finally decided to start the process last month. I purchased a 19" U3100 monitor direct from Wells-Gardner, without really knowing what I was getting into. In the rush to get a new CRT arcade monitor before they go the way of the dodo, I jumped the gun a bit.
So here are a few questions I hope you fine folks can help with:
* Where can I get a power cord for this thing? I see some on the Suzo-Happ site (Part no. 49-5179-00), but not sure if that's what I need exactly.
* I plan to use this in a cocktail cabinet build. After doing some more research, apparently you need the monitor modded in some fashion for it to work in this configuration? What is involved, and where should I look for someone to do this modification? (My electronics skills outside of building PCs is minimal to non-existent) If I don't have it done, will it just look bad, or will it damage the monitor?
* The whole "OMG 20,000 volts" thing with CRTs has me a bit spooked. Any tips/tricks/insulation advice for not getting myself killed?
Thanks in advance - I'm sure I'll have many more questions as I start this adventure!
