noob question
hovo
quebec, Canada
I have an empty arcade cab, and also a tv, which i could remove the screen from it. If i would one day decide to buy a pcb, what else do i need for it to work(exluding the control buttons) ??
as the title says its a noob question,
thanks in advance
Easiest bet is to just buy a video converter which runs the RGB signal into composite/ S-video/ component. Runs around $40
However, the composite signal looks like ass. The s-video looks good. The component signal look the best, but you'd need a good enough TV for that to work.
no i mean parts like power supply...
Something like this...
http://goo.gl/9wEhn
You wouldn't wire your TV into this though. Just the PCB.
Look at this diagram...
http://therealbobroberts.net/basic-ac.gif
If you really wanted to, you could wire the TV power cord into the distribution block. I would just get a power strip with a long cord, mount it internally, and then plug everything into that.
Less chance of you electrocuting yourself.
EDITINIG TO ADD...
If you are using a TV, you DON'T need the isolation transformer pictured in the diagram in the upper right.
