Non working coin door lights
playpin35
Jacksonville, Missouri
The coin door lights did not work when I got my addams family. Checking into the problem I find that the AC voltage is present at the bulb socket, the #47 bulbs are new(verified working in a known working socket) and yet they still do not work. Has anyone had the same problem with such a simple issue as this?
I've checked all connections from backbox to coin interface and found nothing loose. Like I said, the power is present at all 3 sockets, I don't understand why they don't work. Bulb sockets look to be like new condition as well.
I have seen issues where the bases on #44 or #47 bulbs were not the same. Bulbs made over seas mostly and differences by only mm's. Wonder if this is your issue, since voltage is at the socket.
Is the voltage there (6.3 volts AC) with the bulbs installed in the sockets? Or is the voltage only present at the sockets when no bulbs are installed?
