No sound on Time Crisis
JadeKnight
California
I have a Time Crisis machine that is missing the audio.
I've checked the settings under the service menu, and tried adjusting the volume to the max with no effect. I also did a board test, through the service menu, and it reported all the boards were good.
As far as I can see all the wires appear to be connected correctly. I followed them from the speakers to the board(s), and all the connections between the boards appear good. There are no loose wires I can find.
I also couldn't find any physical pots or switches to enable/adjust the volume in the cabinet. I don't know if Time Crisis should have them; since the volume is adjusted through the service menu, and there are no mentions of them in the manual I found.
The person I got it from says it originally had extremely loud audio, and a tech disabled/fixed the audio for them. However, they do not remember how they disabled/fixed it.
Any thoughts, or other things I should check?
afaik, there is a mode where there are no sound in demonstration mode, this is activated through test menu. besides that, if they were to disabled it permanently, they might cut/pull out power to amplifier board (it should be located in the sides of the box).
