No Sound from Golden Tee Cabinet
nefsky
Louisiana
I picked up an original Golden Tee 2004 cabinet the other day that had a dead board set in it. I replaced it with a new Golden Tee Complete board set and it works fine except that I'm not get any sound, I don't even hear the speakers crack when I turn the machine on. I've traced the wiring back and it looks like everything is connected correctly, but still nothing. I've check the system settings and messed with the manual controls on the cab itself and still nothing. Other than the sound everything is working correctly as the coin mechs and lighting comes on, the game displays, etc. Any help would be appreciated.
No, doesn't look there has been anything inside the machine gnawing on things to cause wire fraying. I went through the manual it suggested it may be a bad power connection, but since all the other lights and coin mecs are coming off the same source, I didn't think that was it.
is your power supply putting out 12 volts? if you're not getting any hiss at all then that means you have no amplification. :)
it's a point to consider. if you have a screw terminal power supply in there, check to make sure the lug for the +12 is making contact with the wiring. I highly doubt if the game's running that you will just have a power supply not putting out 12V.
It's got a Peter Chou power supply in it now, so there isn't a terminal screw to adjust other than messing the with voltage output.
The only thing that really confused me about the set up was the power bypass wiring with this supply set up, but since everything else was working correctly it really had me perplexed. The wire leads for +12 +5 Ground coming straight off the JAMMA connector get capped, so I thought that was the issue, but there wasn't any change when I tried running power into those instead of the lines for the lights/coin mec.
The pictures below are from another thread from another users, but its the same set up for wiring as I currently have:
http://tok.home.comcast.net/~tok/temp/IMG_3197.JPG
http://tok.home.comcast.net/~tok/temp/IMG_3196.JPG
