dbstallman
Good evening,
I'm working on a monitor in a friends DK machine and I'm not getting any neck glow.
The fuses are good and I've (not related to this issue) installed a complete cap kit on it and the audio board. I'm getting about 1.7 volts at TP 91, and ~150 volts on both sides of the 300ma DC fuse.
The Q901 transistor shows 150 volts on the collector and 0 or 1.5 volts on the base and emitter. All of the diodes (D601-604) are good when tested off the chassis.
Does that mean IC601 is my next suspect? If so, where is the best place to get one?
Thanks,
Brian.
Thanks,
Brian.
