R3LL1K
I have a 33" showcase and was going to swap out the tube as I have one that looks better. The tube was in another showcase using a Sharp Image chassis.
I pulled the chassis and tube out and didn't really look at the way it was connected. I ended up using the chassis in the Showcase cab I decided to keep a few months ago, but recently I decided to swap the tube as well.
I was looking the tube over before installing it and I noticed that there isn't a grounding strap on the aquadag and no grounding wire to plug into the neckboard? Are there any chassis that don't need one? This is the first time I've run across something like this.
I don't recall throwing away the grounding strap and the degauss coil and everything else looks just like it should. Any ideas? If I plan on using the tube do I or can I just rig up a grounding strap and plug?
