No Fear, start-up problem
Atari123
Atlanta, Georgia
Hi, yet another question from me about No Fear. My game refuses to start up after I went into the back box to look for the hook-up for the knocker. All it will do is display dots on the display but the lights won't come on, when I close the coin door all the flippers go to the up position. Does anyone know what could be the cause of this problem? I tried pushing in all the connectors but that didn't help. If it does help their is this one LED that stays on despite the machine being off and another LED that was flashing when the machine was functional but no longer does so.
Check all of the ribbon connectors, especially if you reseated all the connectors. You may have a ribbon connector that is off by a pin, or a row. Other than that start checking the fuses.
-Mark
alright I checked the connectors and they look like they're in all the pins, I'll see if I can get a multimeter to check the fuses
Okay well I got it to start up but now the flippers aren't working, when this problem started they went into the hold position then stopped after a while. I checked the connectors where I was working and their all in properly.
